Forums >> Revit Building >> Technical Support >> hatching help
Thu, Nov 1, 2007 at 9:59:16 AM | hatching help
rintin2x
I'm a new Revit user, and I hope somebody can help me with this problem. I have revit building 9. i download the hatch pattern from the download section from this website, but when i tried to import it to my revit it giving me this error message "no model type pattern find". Is it because of the version compatibility? Please help me.
 Karolus
Thu, Nov 1, 2007 at 12:02:37 PM | hatching help
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
The pattern file you are trying to attach is made up of only "Drafting" patterns. When you are creating a pattern you have to define if it is "Model" type or "Drafting" type. You can see the pattern if you create a drafting pattern. If you need it to be a model pattern you will need to add the syntax to the .pat file or find a .pat that is set up to be a model pattern.
Thu, Nov 1, 2007 at 12:51:46 PM | hatching help
rintin2x
ok, got it to work...thank you so much for this information.
Karolus
Thu, Dec 20, 2018 at 1:30:39 PM | hatching help
ideaguy
ideaguy Avatar
Just in case you need to know, What is the syntax??, ;%TYPE=MODEL%  for the first or second line works
Topography and hatching in section / elevation
Sat, Sep 27, 2008 at 7:55:41 PM
HATCHING 2008
Fri, Jun 22, 2007 at 11:19:07 AM
Area Plan Hatching
Fri, Oct 26, 2018 at 10:23:00 AM
Topography Hatching
Tue, Feb 28, 2012 at 8:15:31 AM
Changing line weights to hatching?
Wed, Apr 26, 2006 at 10:44:00 PM
Page generation time: 0.2692
