Forums >> Revit Building >> Technical Support >> Column Bubble Size
Tue, Oct 30, 2007 at 4:45:37 PM | Column Bubble Size
BayArch
Hi everyone.  I am fairly new at Revit as I have only been using it for a couple of months.  I have found this website to be a big help!
Anyways, this may be a simple question, but I am at my wit's end at trying to figure it out.  How do you change the size of the column bubble without affecting every view?  I need to produce a composite plan that is half the scale of my floor plans in order to fit it all on one sheet.  I have edited the column bubble family and loaded it into my drawing.  I changed the column bubbles to the correct size in my composite plan, but then when I flipped back to my floor plan, the column bubbles were changed to the smaller size there as well.  Please help.
Problem with Column bubble tag
Mon, Sep 14, 2009 at 3:46:07 PM
Column grid text too wide to fit in bubble
Thu, Jul 1, 2010 at 8:32:06 AM
Different Grid Bubble for different scale views?
Thu, Dec 12, 2013 at 5:42:13 AM
grid types & grid bubble size
Mon, Jul 14, 2008 at 11:23:18 AM
LINKED COLUMN GRID BUBBLE OFFSET
Thu, Mar 25, 2010 at 2:05:39 PM
Page generation time: 1.1080
