Forums >> Revit Building >> Technical Support >> Slab Edges on Sloped Floors
Mon, Oct 29, 2007 at 5:51:25 PM | Slab Edges on Sloped Floors
arkitektmsh
3 Stars: 1 Votes
Revit Architecture 2008
 Is there a way to apply a floor slab edge sweep to a floor that is sloped using the points function and its structure has variable layers?  Could it be the profile or is it that you can't add a floor slab edge sweep to a floor with variable thickness?  Any help would be great, Thanks.
Thu, Nov 15, 2007 at 11:46:55 AM | Slab Edges on Sloped Floors
mebowles55
Did you ever find a solution? I'm running into the same issue.
Thu, Nov 15, 2007 at 1:02:22 PM | Slab Edges on Sloped Floors
arkitektmsh
3 Stars: 1 Votes
Not yet, other thn by tricking Revit by using in-place families to replicate the grade beams.  I'll post to Revitcity with a solution if i fgure it out.
Wed, Aug 12, 2009 at 12:37:28 PM | Slab Edges on Sloped Floors
jhayden
jhayden Avatar
Not sure if you have figured this out yet, but check out this link
http://revitcity.com/forums.php?action=viewthread&thread_id=14005
If you remove the slope arrow, add the slab edge, then re-slope the slab, the edge goes with it
slab edges are brown
Thu, Apr 28, 2011 at 8:58:20 AM
Cutting floor slab edges out of pads
Mon, Oct 25, 2004 at 10:43:54 PM
Slab Egdes & multicategory schedules.
Mon, May 16, 2011 at 2:04:35 AM
Slab edges - square instead of plum?
Thu, Apr 2, 2009 at 7:58:19 AM
Create Void as Slab Edge
Sun, Oct 2, 2016 at 11:39:37 PM
Page generation time: 1.1040
