Forums >> Revit Building >> Technical Support >> plywood hatch
Mon, Oct 29, 2007 at 10:44:33 AM | plywood hatch
Nostromo
I've read a couple of threads of others having similar problems to mine, but have not yet seen a clear answer on how to remedy the problem.  I'm trying to place plywood as a detail component in a section view.  The hatch for the plywood comes out correctly horizontally, but not vertically.  I know that the program is capable of orienting the hatch the correct way because my wall and roof types both contain plywood as a sheathing layer and the hatch for them is oriented properly (vertically for the wall and at an angle for the roof).  How do I get it to work for my detail components?
Mon, Oct 29, 2007 at 10:52:55 AM | plywood hatch
You either need to make a 90 degree plywood hatch or create a model plywood hatch that you can rotate.  A model pattern must have the line ;%TYPE=MODEL in its file right after its name.  You can edit your pat file to add this line then reload it as a model fill.
Plywood Hatch
Mon, Jun 29, 2009 at 6:24:46 AM
Vertical Plywood Hatch Pattern [ 1 2 ]
Mon, Aug 27, 2012 at 4:04:30 PM
17
Filled regions and Hatching
Thu, Aug 24, 2006 at 2:20:06 AM
Plywood
Wed, Oct 10, 2018 at 2:54:49 PM
Custom Rafter Cut for plumb plywood and square standing seam
Sun, Dec 15, 2013 at 10:26:27 AM
Page generation time: 0.2915
