Forums >> Revit Building >> Technical Support >> Stacked Wall Problem pls help!!!
Sun, Oct 28, 2007 at 3:40:59 AM | Stacked Wall Problem pls help!!!
AFKMatrix
Ok I have created a Stacked wall for an external wall which has a retaining wall at the bottom and then a normal wall above it.  The problem is that when I create the floors and it asks me if i would like to cut the wall as it is overlapping the wall (so in section it looks like the floor is resting on the wall) and I say yes it won't cut out the section from the Stacked wall?
 I have tried to do 2 seperate walls and it works here but then I have problems with the Room command as it won't recognise the rooms where the retaining wall is on the bottom.
Mon, Oct 29, 2007 at 8:06:25 PM | Stacked Wall Problem pls help!!!
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
check the properties of the retaining wall and make sure it is set to room bounding
2013 - Stacked wall problems
Thu, Dec 12, 2013 at 8:23:39 PM
Stacked wall problem - corners do not fillet.
Wed, Jul 16, 2008 at 11:40:39 AM
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Stacked Wall Dimensioning
Thu, May 27, 2010 at 3:48:25 PM
Page generation time: 4.3290
