14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Text Formatting
Is there a way to have mutliple text styles in one text box? I am creating a body of text for code notes where the headings, subheadings and body will be different sizes of text, but when I elect to change the size (text style) of the heading, it changes the rest of the text to the same text style. Thanks,
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
I understand that you can only have one style per text box- ie that "is" the style of that specific box. The only attributes you can change on a line-by-line basis is Bold, Italic or Underline. Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
That's what I was afraid of...does anyone have an effective work around for this? It just seams very tedious to have to create numerious text boxes in order to have multiple text sizes.
Just copy (using "Multiples" Have all the different sytles you need already set up. Then once you have pasted in your text into each one- just select it and pick the style from the type selector- overall it's probably slightly quicker than picking each line and changing it's formatting ("if" you were able to do it!) Regards, Ian
Why does Revit text / formatting suck so BAD!?!?! |
Tue, Sep 6, 2016 at 11:14:27 AM
Text formatting (bullets & indents) |
Wed, Jun 11, 2008 at 8:49:15 PM
Text Formatting |
Sat, May 21, 2011 at 11:04:49 AM
Text Issues |
Mon, Mar 9, 2009 at 3:15:07 PM
Arch 2012 Conditional Formatting |
Tue, Sep 18, 2012 at 11:08:38 AM
