Forums >> Revit Building >> Technical Support >> How to make a recessed panel in a masonry wall
Wed, Oct 24, 2007 at 9:42:59 PM | How to make a recessed panel in a masonry wall
JMD511
I have a brick veneer wall system and can't figure out or don't really know the best way to add a recessed brick panel.  And to make it more difficult the recessed panel would have a herringbone pattern.  Recess would only be 1"-2".  I'm using Revit Arhcitecture 2008.
Thu, Oct 25, 2007 at 2:07:58 AM | How to make a recessed panel in a masonry wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
A couple of options:
A Stacked Wall OR
a Basic/Compound Wall with a wall Reveal and a separate material painted to the reveal to give the herringbone pattern...
 HTH.
Regards,
Chris.
Thu, Oct 25, 2007 at 6:58:39 AM | How to make a recessed panel in a masonry wall
I think this would best be done with a family that has a vopid the size of your panel and a veneer withit that has your herringbone design.  You can then place that anywhere.
Thu, Oct 25, 2007 at 5:29:09 PM | How to make a recessed panel in a masonry wall
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, I didn't think the actual shape of the recess was herringbone shaped...
As such I would make it as a face based generic model void setup with an array that can be dragged out similar to a line based family.
Regards,
Chris.
Fri, Oct 26, 2007 at 7:19:46 AM | How to make a recessed panel in a masonry wall
Just to clarify my post, I did not mean a herringbone shaped area.  I suggested a family with a void to cut the wall and a face that had a herringbone pattern / accurender material either assigned to it our poured on its face.
concrete wall and masonry wall to have different lineweights
Thu, Jan 6, 2011 at 12:39:04 PM
curtain wall panel losses end - edge
Tue, Jul 15, 2014 at 7:04:22 PM
Wall type with recessed wd panels
Thu, Jun 21, 2012 at 7:34:31 AM
RECESSED PANELS IN EXTERIOR WALLS
Mon, Oct 31, 2005 at 4:22:37 PM
Arched Window in Masonry Wall
Mon, Mar 4, 2013 at 5:28:03 AM
Page generation time: 1.0546
