Forums >> Revit Building >> Technical Support >> Plan wall cut hatch not orienting itself with wall
Wed, Oct 24, 2007 at 4:59:22 PM | Plan wall cut hatch not orienting itself with wall
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I am trying to get a basic wall hatch in my plan.  I want a 45 degree diagonal hatch in my cut walls.  But if my walls are not 0 or 90 degrees then the hatch does not look right.  The hatch is set to run at 45 degrees regardless of what angle my walls are running.  SO when I do draw an angled wall (in this case 45 degrees) the hatch virtually dissapears because it is running parallel with the wall.  Is there a way to orient the hatch pattern to run 45 degrees dependent of the angle my wall is at?  Does this make sense?  I can post a picture of it if need be.
Denver, CO
Revit Architecture
Wed, Oct 24, 2007 at 5:04:46 PM | Plan wall cut hatch not orienting itself with wall
TomDorner
4.5 Stars: 25 Votes
Fill patterns (drafting) have three types of orientation:  Orient to View, Keep Readable, and Align with Element.
Either edit your pattern to Align with Element or better yet create a new pattern with that property and indicate the alignment in the name of your pattern.  To adjust add patterns go to Settings>Fill Patterns then select the one in question and hit the edit button.  There you will be able to adjust the orientation value.
HTH
Tom
Wed, Oct 24, 2007 at 5:36:16 PM | Plan wall cut hatch not orienting itself with wall
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
thanks I knew it was something simple...it always is. Puh
Denver, CO
Revit Architecture
Getting Cut Wall Hatch to move WITH the Wall
Fri, Aug 10, 2012 at 2:59:50 PM
Cut plane hatch missing from one type of wall
Tue, Sep 20, 2011 at 9:54:20 AM
Phase "new" in plan: doors cut pattern same as wall
Tue, Dec 8, 2015 at 7:40:25 AM
Showing column cut on top of wall cut pattern
Tue, May 28, 2013 at 4:06:05 AM
Plan Region not shwoing wall hatch??
Mon, Jan 14, 2008 at 12:03:29 PM
Page generation time: 1.2185
