Forums >> Community >> The Studio >> door tag
Wed, Feb 16, 2005 at 3:47:31 PM | door tag
aabrmn
I just lost all door tags in my plan view. if I insert a new door comes with the tag but how do I get back my door tags for the existing ones? Any help is extremely appreciated.
Wed, Feb 16, 2005 at 3:51:17 PM | RE: door tag
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
on the drafting tab, choose "Tag all not tagged" and select door tags. This will tag all doors that are not currently tagged.
Hiroshi Jacobs
Wed, Feb 16, 2005 at 4:58:47 PM | RE: door tag
aabrmn
Great! Thanks! By the way, do you have any idea why they disappeared? I do not remember deleting them... Thank you very much.
Wed, Feb 16, 2005 at 5:42:38 PM | RE: door tag
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
they are view specific so if you placed them in one view they won't appear in another unless you tag them again. My guess is that you're just looking at a different view now...
Hiroshi Jacobs
Wed, Feb 16, 2005 at 7:41:31 PM | RE: door tag
aabrmn
That must be the reason why. I guess I got all scared for no reason. Thanks. Have you ever experienced any problem with three walls joints working with worksets? I posted a thread about it yesterday. I am still experiencing problems with this issue and I can not figure what I am doing wrong... Thank you Hiroshi. Post edited on 2005-02-16 21:39:21
Wed, Feb 16, 2005 at 9:40:24 PM | RE: door tag
aabrmn
here is another example
Wed, Feb 16, 2005 at 10:22:33 PM | RE: door tag
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
drag the bottom wall so it unjoins from the two other walls. Trim them together so they join as expected. Use the wall join tool on the end of the lower/unjoined wall and select "disallow join", then drag the wall end right up to the face of the horizontal wall. This will fix the problem, however you will end up with a line between the walls. Bet than the alternative though.
Thu, Feb 17, 2005 at 4:25:38 PM | RE: door tag
aabrmn
That worked for one particular case but what would you suggest in a case like the one attached?
Thu, Feb 17, 2005 at 5:11:41 PM | RE: door tag
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Ensure you are using the latest build. Make sure all adjoining walls are part of the same workset, if not change them so they are. Then, I'm assuming you have got them to display properly and these are the ones that are losing the joins when you reload worksets of save to central?, anyway use the trim tool and the wall join tool to get them to join correctly. Hopefully it will retain this data when you save to central then... Disallowing joins obviously won't be much help here, either that or become friends with filled regions to cover over the joins themselves... HTH.
Thu, Feb 17, 2005 at 8:51:59 PM | RE: door tag
aabrmn
I will check about the latest build with our IT manager. Thanks for all your help.
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:39 PM
Door tag placement??
Thu, Jun 8, 2006 at 11:44:11 PM
Page generation time: 0.3272
