Forums >> Revit Structure >> Technical Support >> Detail Callouts missing! Latest build didn't fix!
Wed, Oct 24, 2007 at 2:10:57 PM | Detail Callouts missing! Latest build didn't fix!
TyMad
I currently have the latest version of Revit Structure 2008 & my detail callouts are still missing. I read that the latest version they fixed them from disappearing but they aren't there. The visibility settings are set correctly & I tried clicking the light bulb for the hidden items & they still don't show up. Section callouts show up just fine but the detail callouts won't. Any advice on how to fix this would be much appreciated!
Wed, Oct 24, 2007 at 2:45:30 PM | Detail Callouts missing! Latest build didn't fix!
NKramer
4 Stars: 9 Votes
Try changing your scale. For instance your detail callouts may be hidden at scales corser than 1/8" and you are looking at a 1/16" drawing.
If that is the case then after you find your detail callouts you will need to go into the properties of each one (I dont know if you can do multiples at once) and change the "hide at scales corser than" variable.
Thu, Oct 25, 2007 at 8:13:13 AM | Detail Callouts missing! Latest build didn't fix!
TyMad
That worked! Thank you very much! That was driving me crazy lol
Thu, Oct 25, 2007 at 10:03:55 AM | Detail Callouts missing! Latest build didn't fix!
NKramer
4 Stars: 9 Votes
Just as an FYI the default for hid in scales corser than  is set to whatever scale your drawings are in. I.E. if you draw a callout in an enlrged plan at 1/4" scale it will hide at scales corser than 1/4" and thus will not show up on your 1/8" floor plan.
Adding SIM / TYP to Detail View Callouts [ 1 2 ]
Thu, Feb 26, 2015 at 2:00:21 PM
18
Window Legend Detail Callouts
Sun, Jun 8, 2008 at 8:21:58 AM
Don't know why i didn't think of this sooner....
Mon, Oct 13, 2008 at 12:53:08 PM
multiple section callouts
Wed, Jun 4, 2008 at 9:04:18 AM
Unrecoverable Error - Decal
Tue, Dec 6, 2005 at 3:59:29 PM
Page generation time: 2.6757
