Forums >> General Discussion >> Wishlist >> Phasing moved to Visibilty/Graphic
Wed, Oct 24, 2007 at 1:20:59 PM | Phasing moved to Visibilty/Graphic
tomkriegshauser
Since the Phasing element properties are visibility related, should the Phasing 'phase filter' and 'phase' be placed under a tab on the Visibility/Graphic dialog box, similar to Design Options and Worksets?
Wed, Nov 18, 2009 at 9:38:08 AM | Phasing moved to Visibilty/Graphic
paulcorb
2 Stars: 1 Votes
I am new to revit and revit city , looking for help from a pro out there !
i designed a floor plan , added tables and a bar ect , the question I now have is how do I get to like camera mode so i can shoe the layout in 3d perspective as in like walking in door  and pysically seeing tables bar ect ?
Wed, Nov 18, 2009 at 10:00:19 AM | Phasing moved to Visibilty/Graphic
Read your help ... do a search of the help using camera and you will find several topics including how to place and modify your camera.
The HELP function in REVIT is very good if you learn to use a one word search.
Wed, Nov 18, 2009 at 10:24:49 AM | Phasing moved to Visibilty/Graphic
paulcorb
2 Stars: 1 Votes
thanks i found it . again i am brand new to revit been stck on this for days again thanks revit city
Wed, Nov 18, 2009 at 12:20:38 PM | Phasing moved to Visibilty/Graphic
paulcorb
2 Stars: 1 Votes
hello again ... next ? when downloading objects to be copied to my drawing ... i have revit 2008 , and yes i tried filtering to 08 after copiy i try loading to my drawing and it will not it keeps telling me its newer version can not copy to older anyway around this ??????
forgive me i am NEW
Wed, Nov 18, 2009 at 4:11:56 PM | Phasing moved to Visibilty/Graphic
Revit is not backward compatable.  Sorry  You need objects from your release or earlier.
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
Phase Graphic Overides
Tue, Sep 18, 2018 at 8:42:53 AM
Phasing vs materials...Who is the boss when it comes to graphic overrides?
Mon, Nov 12, 2012 at 9:07:55 AM
Phase Graphic Overrides
Wed, Jul 10, 2019 at 4:01:45 PM
Phasing & graphic overrides
Sun, Apr 18, 2010 at 12:25:14 AM
Page generation time: 4.4538
