7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> can't use duplicated views as underlay
6 Posts No Rating |
Hi all. I've got a duplicated view of a plan, on which I've made some drafting lines. I need the lines as underlay on the upper floor, but when I look at the properties of the upper view I can't find the dublicated view in the list of posible underlay views. Anyone knows how to fix this? Lasse...
hi, underlay is not view specific its level specific. it shows everything in that level and it doesn't matter if say your furniture is turned off in level one it will still show up on level 2 underlay. since you used drafting lines which are view specific you can't get them to show up in an underlay. or any other view except the one the where created on. you should use model lines instead and only of shown them in the views you want.
can't find ceiling plans in underlay parameter |
Wed, May 4, 2016 at 8:52:38 AM
11
Underlay Issues |
Wed, Mar 29, 2006 at 11:52:24 AM
Plan Range - displayingn duplicated views |
Wed, Aug 1, 2007 at 8:45:02 AM
Duplicated view - perset |
Fri, Jun 15, 2007 at 10:49:53 AM
Sheet Underlay |
Fri, Sep 12, 2014 at 2:13:25 PM
