23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Mass to Wall as a solid
Hello, is there a way to change an existing mass to say a wall mass or anything else. My dilema is that I have a bunch of existing buildings that are masses, that I need to stay there. I also have some more masses that I used to make walls by face, and I want to hide them, without deleting them in case I have to use them later. What I want to do is to make the existing masses(other buildings) to show up but not the ones I used for my building. Can I change the existing masses to a different type so I can turn off my mass in visibility graphics to turn off the mass under the walls by face of my building? Thanks , I hope this was clear to understand?
ok 2 ways to do this if usuing 2008 select the masses you want to hide and use the temporary hide isolate tool other option is to ste up a filter under the vvv if you are going to be turning them on and off a lot this is the best option
Thanks for the help. What I did is select the masses I wanted to hide and made a group out of them. It was easier for me to temp hide isolate them. thanks again
Sweeping Solid In-Place Mass |
Tue, Apr 27, 2010 at 3:30:38 AM
Making an object from solid mass... |
Mon, Oct 25, 2010 at 7:17:06 AM
Need help building stucco mass |
Tue, Feb 26, 2008 at 12:03:05 PM
Autocad 2011 Solid To Revit 2011 Mass floor error |
Mon, Feb 28, 2011 at 7:20:10 AM
create floor or other solid mass from Topo |
Wed, Oct 2, 2013 at 9:29:26 PM
