Forums >> Revit Building >> Technical Support >> Problem loading profile for slab edge sweep.
Sun, Oct 21, 2007 at 11:44:46 AM | Problem loading profile for slab edge sweep.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Revit 2008 - I am wanting to host a sweep on a slab edge.  This is actually an edge of an asphalt drive.  I created it as a floor offset down to the drive level.  Made the materials of the floor asphalt with a gravel base.  I have created a profile of a concrete curb detail that we commonly use.  I load that profile into the project, but when I go to the host sweep command and attempt to create the new sweep, I don't find the concrete curb profile that I loaded.  I find all of the other sweep profiles in the project that I have loaded for wall sweeps and roof sweeps, but not the one I need.  There must be something really basic that I am missing.  Any help will be appreciated.
Sun, Oct 21, 2007 at 11:50:03 AM | Yes, I went through the standard procedure.............
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Here is a previous post about doing a new wall sweep:
 http://www.revitcity.com/forums.php?action=viewthread&thread_id=4514
I did exactly as described for the slab edge sweep and the loaded profile is not there.
Mon, Oct 22, 2007 at 8:04:06 AM | Problem loading profile for slab edge sweep.
KimWong
KimWong Avatar
3 Stars: 2 Votes
Go to edit your profile again and see if the lines are all joined or IF you have additional line that overlap and was not erased. Turn on the bold line to help you see better.
Then reload the profile into the project again.
That is usually the problem.
Edited on: Mon, Oct 22, 2007 at 9:11:58 AM
G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong.
Slab edge profile not available
Tue, Nov 10, 2009 at 1:56:29 PM
Revit 2012 - Partial slab edge - how to?
Fri, May 9, 2014 at 8:03:21 AM
C-Channel Profile sweep issues?
Fri, Apr 29, 2011 at 11:47:24 AM
Slab Edge Profile... Except Up...
Wed, Nov 11, 2009 at 7:00:24 PM
slab edge profiles
Fri, Oct 31, 2008 at 12:10:37 PM
Page generation time: 0.6332
