Forums >> General Discussion >> Wishlist >> only show wall cut
Wed, Feb 16, 2005 at 9:37:32 AM | only show wall cut
jterrell22
i would like to be able to only show a wall when it is cut. i.e. - i have done several houses where the second floor is a loft within the trusses of the house. my plans look pretty messy when showing the projected sloping walls. if i could set a cut plane for the walls that was independant of the view's current range, i could only show walls that intersect with that cut plan. maybe i'm not explaining enough. i just want to see the cut wall, nothing above or below it, and have that cut plane be adjustable. *i wish*
Show two cut/ fill patterns in on wall
Thu, Mar 5, 2015 at 8:16:16 AM
5'8" wall will not be cut by cutplane
Mon, Nov 13, 2017 at 3:49:59 PM
Wall sections cut from elevation... now not seen on plan
Fri, Mar 9, 2012 at 11:05:12 AM
Earth and Wall cut patterns not showing in wall section...
Thu, Jan 5, 2012 at 3:08:36 PM
make elevation cut line show from diffrent planes
Thu, Jul 9, 2009 at 2:10:05 PM
Page generation time: 2.8966
