Forums >> Revit Building >> Technical Support >> Turning off Interior elevations on Site plan, but keep Exterior on?
Thu, Oct 18, 2007 at 2:35:32 PM | Turning off Interior elevations on Site plan, but keep Exterior on?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I'm sure this is something simple, but I have two types of elevation families.  Interior and Exterior.  On the site plan I want to turn off the interiors and show the exteriors.  But in my VV they are all under just one category with no subcategories.  So I can't turn off just interiors.  Does anyone have a solution to this rather than me individually selecting all and hiding in view?
Thanks,
Lorne
Denver, CO
Revit Architecture
Thu, Oct 18, 2007 at 7:46:33 PM | Turning off Interior elevations on Site plan, but keep Exterior on?
lab21
Highlight an interior elevation symbol in your site plan view, right click and select all instances (this should select all interior elevation symbols). Right click again and select Hide in view - elements. Or for pre 2008 version Hide annotation in view.
 HTH
Fri, Oct 19, 2007 at 12:38:04 PM | Turning off Interior elevations on Site plan, but keep Exterior on?
TomDorner
4.5 Stars: 25 Votes
Another approach is to set a value in the 'hide at scales courser than' box in the properties of the elevation.  For instance your floor plans are at 1/8" scale and you want the elevation markers not to show on the site plan which is at 1:200.  Then set the properties of the elevation to not display at scales smaller than 1/8".  See the attached image for further explanation.
Tom
turning on layers in plan and off in elevation
Fri, Mar 26, 2004 at 9:06:39 AM
Interior Lighting from an exterior view
Wed, Nov 11, 2009 at 12:41:44 PM
Interior/Exterior elements in same view
Wed, Jul 25, 2007 at 11:37:33 AM
Placing building elevations
Mon, Jan 30, 2012 at 7:32:27 PM
ELEVATION MARKERS IN PLAN
Thu, Aug 3, 2006 at 10:36:43 AM
Page generation time: 0.5478
