Forums >> Revit Building >> Technical Support >> room tags in enlarged plans
Wed, Oct 17, 2007 at 6:49:08 PM | room tags in enlarged plans
hunterfloyd
I cannot for the life of me get room tags to appear in an enlarged restroom view.  All of the visibility settings appear to be on, but when I try to place a room tag in the enlarged plan, revit gives me the message  "None of the created elements are visible in Detail View: RESTROOMS View. You may want to check the active view, its Parameters, and Visibility settings."  Please help.
HuntFlo
Thu, Oct 18, 2007 at 1:23:24 AM | room tags in enlarged plans
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I assume you are using 2008... try turning off the annotation crop region as it maybe causing some abnormality in your view.
Alternatively use the "Reveal Hidden Elements" to ensure they are not hidden in the view.
HTH.
Regards,
Chris.
Thu, Oct 18, 2007 at 12:30:49 PM | room tags in enlarged plans
hunterfloyd
Indeed I am using 2008, sorry I forgot to mention it.  I turned off the annotation crop, and tried placing a room tag into the view, and still no dice.  Any other ideas?  Thanks for the help.
HuntFlo
Sun, Oct 21, 2007 at 7:45:19 PM | room tags in enlarged plans
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Didn't notice this the first time I looked at your post...
 Detail Views have a few special characteristics where items are off by default and I don't believe you can turn them back on...
 Recreate your callout using the "floor plan" in the type selector instead of the detail view.
 HTH.
Regards,
Chris.
Mon, Oct 22, 2007 at 1:18:24 PM | room tags in enlarged plans
hunterfloyd
thats the ticket.  thanks for your help spot man.  any chance there's a way you can convert detail views to floor plan views without deleting them and reinserting?
HuntFlo
Tue, Oct 23, 2007 at 11:45:52 AM | room tags in enlarged plans
laurabh
Nope - you have to recreate them.
Tue, Jan 13, 2009 at 9:11:57 PM | room tags in enlarged plans
elduderino1234
I am having the same problem using RAC 2008. I create a callout on my floor play to create an enlarged view. Floor plan, not detail view, is selected but still no room tags show up. I unchecked crop annotations and they are not hidden. Any ideas?
Wed, Jan 14, 2009 at 8:38:25 AM | room tags in enlarged plans
Rooms and room tags have to be on in VG.
Wed, Jan 14, 2009 at 11:52:09 AM | room tags in enlarged plans
elduderino1234
I have Rooms (under Model Catefories) turned on will all sub-elements turned on (Color fill, interior fill, reference) and Room Tags turned on under Annotation categories but I still cannot see the tags in a callout floor plan. Any ideas?
Wed, Jan 14, 2009 at 12:21:16 PM | room tags in enlarged plans
elduderino1234
I should note that the rooms are still there and I just have to re-insert the actual room tag back into the floor plan. Not a major task but one that I don't really feel like doing because revit should display them automatically.
Wed, Jan 14, 2009 at 12:37:18 PM | room tags in enlarged plans
#11
Room tags are annotations - not model elements.  Therefore, unless you copy a view with details, the annotations will not be there.
Likewise, no callouts will contain annotation elements either ...until you place the.  This is very easy to do in REVIT.  Window you base view & filter it for the annotation elements you want to copy and copy / paste them same place.
Area and Room Tags
Thu, Apr 16, 2009 at 2:48:06 PM
room tags in sheet view
Thu, Jun 8, 2006 at 9:35:24 AM
Room Tags on Demo Plans
Mon, May 9, 2022 at 3:23:12 PM
Door/Room Tags in Callout Detail
Thu, May 17, 2007 at 3:18:42 PM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Page generation time: 0.2961
