Forums >> Revit Building >> Technical Support >> imported dwg on different elevations
Tue, Oct 16, 2007 at 7:24:00 AM | imported dwg on different elevations
architurk
architurk Avatar
3.5 Stars: 3 Votes
i have imported one .dwg to be seen on the current view only. how can i manage to move it perpendicular to that view? Crying=moving it closer or far from my point of view)
 thx
Tue, Oct 16, 2007 at 7:41:46 AM | imported dwg on different elevations
mmetin
mmetin Avatar
You may be able to rotate or align it in Site Plan view....Or in 3D view Go view/Orient View to top and select that dwg (use filter selection to select it easily, you may not even see it) after selection rotate,move copy commands will be active....
 And some Turkish explanation to my friend:
 Mrb. ben bir kesite asansör detayı eklemek için kullanmıştım import olayını. Msn den görüşebiliriz. mmetin_60hotmail
Tue, Oct 16, 2007 at 8:10:06 AM | imported dwg on different elevations
KingRevit
4 Stars: 12 Votes
go into a plan view
then go into your elevation
select the dwg
Ctrl & Tab - to go back to your plan view.
move tool.
then move your dwg.
note when you use currrent view only moving it forwards the elevation in plan doesn't really do anything, i think what you should do is in the elevation view select the dwg then on the options bar click - bring to front.
Annotations accidentally snapped into linked dwg (Imported categories)
Tue, Jul 9, 2013 at 5:53:11 AM
Section or elevations not cutting imported dwg's
Fri, May 9, 2008 at 3:30:44 PM
DWG and revit preformance
Mon, May 15, 2017 at 2:24:05 AM
Materials of Imported DWG files
Sat, Oct 17, 2009 at 3:47:08 PM
not to see imported dwg on every level (after importing dwg)
Sun, Nov 26, 2006 at 11:13:58 PM
Page generation time: 0.8645
