15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Pin Position
what's the difference between pin position and locking a dimension? don't they both create a constraint the same? when would you use one instead of the other?
When you import a dwg or image into Revit, use the PIN to pin down its position. This is to avoid accidentally moving it if you are tracing over the info. As for contraint, you basically "locked" e.g the dimension, from being changed. So if you move the wall, the dimension remains the same. In some cases, Revit will warn there is a contraint attached to the object. I don't think you can contraint a file you import into Revit.
----------------------------------- G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong. |
locking the walls in other levels |
Fri, Jul 28, 2006 at 7:29:08 PM
When to pin, When to lock - Best practices |
Tue, Nov 27, 2007 at 8:43:11 AM
Can't pin linked file |
Fri, Oct 16, 2009 at 11:50:41 AM
"Lock/Pin" Linked Architectural Model |
Fri, Feb 11, 2011 at 10:13:52 AM
Imported image troubles, can I "pin" it? |
Wed, Nov 19, 2008 at 2:03:41 PM
