Forums >> Revit Building >> Technical Support >> Stair Baluster Panel Pattern Length
Sat, Oct 13, 2007 at 10:23:19 AM | Stair Baluster Panel Pattern Length
markowings
I have used the standard railing style from Autodesk to create a similar railing style that I need for my project; however, I cannot adjust the length of the glass panels.
The glass baluster panels were set up at 24" in length. I opened the family and created an additional 5'-0" panel. I loaded this into my project, but now the panels overlap, and there appears to be no way to respace the panel length (see attached dialog). If I could adjust this, I could get my railing to look correct.
Anyone have any ideas. I must be missing something here.
Thanks,
Mon, Oct 15, 2007 at 7:05:56 AM | Stair Baluster Panel Pattern Length
KingRevit
4 Stars: 12 Votes
It look like its the "distance from previous" and "offset" that are wrong. distance from previous should be half the distance of the  glass panel. this should get you pointing in the right dirrection.
Mon, Oct 15, 2007 at 9:20:32 AM | Stair Baluster Panel Pattern Length
markowings
Thanks! That is what I was looking for. I knew it would be something simple, but I just kept overlooking it. Thanks again for your help.
Mon, Oct 15, 2007 at 10:04:52 AM | Stair Baluster Panel Pattern Length
KingRevit
4 Stars: 12 Votes
no problem
Glass Baluster Pattern extends beyond segment end
Thu, Mar 14, 2013 at 9:59:59 AM
Glass Panel Baluster Issue
Wed, Nov 2, 2011 at 4:13:25 PM
12
Baluster-
Tue, Nov 15, 2005 at 11:21:46 AM
Simple Baluster Placement Not simple?
Tue, Oct 16, 2012 at 7:42:43 AM
stair railings-inserting glass
Mon, Dec 9, 2013 at 11:37:40 AM
Page generation time: 1.5829
