14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Display of detail marks
when I change the scale of a drawing from 1/4" to 3/16", the detail marks dissappear. Where do you control display characteristics for different drawing scales?
I found the answer: clik on the detail mark, right click and select "properties". Change the setting "hide at scales coarser t than" to the desired value. It defaults to 1/4". Unfortunately, this only can be done by selecting one mark at a time, not globally. You can't do this by "select all similar" function, because it also will select the details with a "SIM" tag, which can't be set to "hide at scales coarser than".
Break Marks |
Fri, Nov 14, 2008 at 6:53:42 PM
Detail section marks appearing EVERYWHERE!!!! RAC 2008 |
Fri, Feb 8, 2008 at 1:01:06 PM
similar detail marks |
Fri, Jan 24, 2014 at 1:37:20 PM
Wall section marks not showing in roof plan |
Thu, Jun 10, 2010 at 2:08:07 PM
Limiting section mark display |
Fri, Feb 24, 2017 at 1:19:26 PM
