Forums >> Revit Building >> Technical Support >> exporting to 3dMAX
Mon, Feb 14, 2005 at 7:49:37 PM | exporting to 3dMAX
laBOMBA
Hi, I want to know if you can export different wall finishes in different layers so I can easily select them in 3d studio max... It is clumsy that revit puts all the walls in the same layer.
Mon, Feb 14, 2005 at 9:12:21 PM | RE: exporting to 3dMAX
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Haven't used max before only viz, have you tried to see if the revit plugin for viz works with max? This may make the transition a little easier.
Exporting REVIT 8 Model into Autodesk 3DMax 7 for Rendering
Wed, Jun 22, 2005 at 9:34:22 AM
Revit to 3dmax
Wed, Mar 18, 2015 at 3:24:23 PM
Revit to 3DMax - issues?
Wed, May 21, 2008 at 6:23:46 PM
3dmax bitmap path adding?
Thu, Mar 30, 2006 at 5:32:44 AM
Revit 2011 into Sketchup?
Mon, Jul 9, 2012 at 11:18:31 AM
Page generation time: 1.0311
