Forums >> Revit Building >> Technical Support >> Visibility Parameters
Thu, Oct 11, 2007 at 12:32:10 PM | Visibility Parameters
NKramer
4 Stars: 9 Votes
How do you link the visibility of a group (inside of a familty) to a Yes/No parameter. I thought that I had the correct formula but Revit doesnt seem to like it.
I would like to be able to turn the Student and faculty Desks off and on per instance.
Also is teher a general setting for the default number of backups or is that a per file setting?
Thu, Oct 25, 2007 at 9:19:37 AM | Visibility Parameters
IDN101
2.5 Stars: 3 Votes
Can I ask: Are you comfortable with using the Family Editor and creating your own components?
 If so....
 You need to set up a parameter, of the type Yes/No.
You then can control the visibility by using a Formula. I "think" it's something like "If Visibility=1" or something like that, entered into the Formular box of the setting you wish to control.
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Thu, Oct 25, 2007 at 9:48:59 AM | Visibility Parameters
NKramer
4 Stars: 9 Votes
I have been working with the family editor but I didnt know what the formula was. I knoew it could be done but after a few tries I gave up and created 2 families or groups.
Mon, Jan 28, 2008 at 10:04:21 AM | Visibility Parameters
malfonsi
4.5 Stars: 2 Votes
I have been trying to control visibility within a family too, and I just figured it out.
 1) The object that needs to be visibly controlled within the family needs to be created as its own family and inserted as a component. Make sure under the "Settings" pulldown menu, select "Family Category and Parameters" and check the box next to the "Shared" Parameter.
2) Insert the object as a component in your family.
3) Open your "Family Types" window and pick the "Add" button under the "Parameters" heading.
4) Select the following in the "Parameter Properties" dialog box. a) "Family parameter" b) Under "Discipline:" select "Common" c) Under "Type:" select "Yes/No" d) Check the dot next to "Instance" e) Add a name unde "Name:" of your choice f) Select a "Group parameter Under:" to your preference.
5) Select "OK" when done with this.
6) Select the object you want to controll the visibility of and pick properties.
7) In the "Element Properties" dialog box, under the "Graphics" heading and at the right end of "Visible" select the little blank button.
Shadey The "Associate Family Parameter" box appears. Now select the parameter the you just made and select "OK" and hit "OK" again in the "Element Properties" box.
 I can not open your file because I am in Revit 9.1, but I hope this helps.
Mon, Jan 28, 2008 at 10:39:23 AM | Visibility Parameters
NKramer
4 Stars: 9 Votes
Actually this is a rather old post. I have since figured out the yes/ no parameter formulas. I dont remember what the exact problem is but I believe that it had something to do with adding the "if" and figuring out the arguments.
Basically if I want to use the output of a yes/ no paramenter then the formula is something like this if(Locks,"A","B"Winking as opposed to the output of a integer parapmeter if(Locks=1,"A","B"Winking. And if you want to use a formula to define a yes/ no paramenter then its something along the lines of Locks=1 for integer parameters or not(Locks) for yes/ no parameters.
I keep trying to go back to excel formulas and that doesnt quite work. I think that I have most of Revit's formula quicks figured; let me know if you get stuck or need help.
As a side note  malfonsi is correct in that you cannot control the visibility (or much else) of an entire group , instead each component of the group must be selected through the group edit dialogue.
Thanks,
Nick
Visibility Formula in Family Parameters
Mon, Apr 24, 2017 at 6:06:35 PM
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:02 AM
controlling visibility with parameters
Wed, Dec 31, 2008 at 11:53:55 AM
Family elements replacable in instace level?
Tue, Oct 30, 2007 at 5:07:45 AM
"Default" Shared Parameters
Tue, Apr 27, 2010 at 2:55:57 PM
Page generation time: 0.4671
