Forums >> Revit Building >> Technical Support >> Multiple Hatches on a wall
Thu, Oct 11, 2007 at 11:40:16 AM | Multiple Hatches on a wall
johnnyutah54
Is there a way to specify a wall type that would show a standard masonry cross hatch when cut, with an additional solid grey hatch over/under the cross hatch?  This would allow differentiation of say a typical 8"x16" CMU wall and a 8"x8" wall in plan.
Fri, Nov 9, 2007 at 4:49:23 PM | Multiple Hatches on a wall
johnnyutah54
I still have no idea if this is possible or how to achieve it.  I have the same problem in elevation views, where I have split-face CMU and regular CMU on the same wall. I would like to be able to differentiate the two with an additional hatch OVER one of the CMU hatches.  Any help?
Mon, Nov 12, 2007 at 8:06:27 AM | Multiple Hatches on a wall
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
When we have a situation where layering two hatches is necessary, we make a separate, single hatch that combines the two we want layered. For instance, we have a fire-rating hatch with a CMU crosshatch in the background...you could do a CMU hatch with a grey background and use it separately from the plain CMU crosshatch.
Export to DWG: distinguish Wall hatches from the inner and outher wall lines
Wed, Mar 1, 2006 at 8:34:41 AM
PROBLEM WITH WALL HATCHES
Wed, Mar 16, 2011 at 5:25:54 AM
How To Turn Off Hatches
Mon, Feb 11, 2008 at 3:27:14 PM
Wall Hatches in Section and Plan
Tue, Jun 12, 2012 at 4:44:06 PM
2 hatches on 1 wall?
Tue, Jun 24, 2008 at 3:49:31 PM
Page generation time: 1.9455
