12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Section Cut heads and tails automatically toggle on when you adjust crop region
46 Posts No Rating |
I am usuing Revit Structure 2008 and I have alot of my section cut heads and tails toggled off to create my drawing. For instance having two different detail bubble heads on a single cut, I will toggle one tail off and stack the bubbles together. Other times to get a detail cut to fit into a small area, like needing the bubble to be angled off of the cut, which revit's split section does not usually accomplish what I am needing it too, so I will make two cuts and turn off one head and one tail, rotate that head and then merge the two together (which was supports suggested work around). Always seemed to be fine before, but now with Revit 2008, if I change the crop region on the plan, everything (related to detail or section cuts) that was toggled off, instantly turns back on... anybody else have a similar problem or know how I can get them to stop turning back on??
Crop region not affecting grid lines |
Tue, Oct 19, 2010 at 4:00:29 PM
Section heads keep moving when view is cropped! |
Fri, May 15, 2009 at 10:06:36 AM
Section heads not moving with crop box |
Tue, May 22, 2012 at 3:26:47 PM
Section cut lines |
Tue, Feb 2, 2010 at 9:44:41 AM
Section Cut tails |
Wed, Mar 28, 2007 at 1:46:10 PM
