Forums >> Revit Building >> Technical Support >> overwriting text in dimension tool
Tue, Oct 9, 2007 at 11:27:46 AM | overwriting text in dimension tool
bhumika
I would like to use the dimension tool in my details, but need to overwrite the actual numerical value with text.  This was possible in AutoCAD, can I do the same thing with Revit 2008?  I know there is a prefix and suffix option, but I need the numerical dimension to disappear... any suggestions?
Tue, Oct 9, 2007 at 12:09:30 PM | overwriting text in dimension tool
sdbrown
5 Stars: 3 Votes
I just type text over the dim. It hides the dim text just fine.
Tue, Oct 9, 2007 at 12:18:35 PM | overwriting text in dimension tool
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
For more on the subject, just do a Forum search for "text" and "override". This has been much debated.
Overwriting Dimension with Text
Thu, Jan 11, 2007 at 11:13:56 AM
Dimension Text [ 1 2 ]
Tue, Jul 8, 2008 at 9:15:07 AM
18
Multiline text below dimension
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
Page generation time: 0.7610
