Forums >> Revit Building >> Technical Support >> linework nodes in section
Fri, Oct 5, 2007 at 8:10:01 PM | linework nodes in section
eyeeye
When I go to use the linework tool in a section or a plan view, I don't get the little nodes at the endpoints of the line so I can control the length of  the linework override.  I can see the little blue nodes in elevation, but not in section.
 I know the Revit Help menu says: "If you are changing the line style for a single edge, rather than an entire component, blue controls display at each end of the edge." I think I am not controlling an entire component in section, just an edge.
Heeeelp!
Thanks lots!
Fri, Apr 25, 2008 at 11:39:35 AM | linework nodes in section
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
I am coming across this issue..has anyone else came across this and/or found a solution.workaround?
 Thanks,
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Thu, Oct 16, 2008 at 8:53:07 AM | linework nodes in section
JRMello
This one's bugged me for a long time. It be nice to at least understand when and why it happens.
Surface Nodes. Help.
Mon, May 10, 2010 at 3:55:51 AM
Linework Tool nodes and adjustments
Wed, Sep 7, 2011 at 6:27:02 PM
Section Head alignment options and Linework assignment to groups or selections
Tue, Jun 13, 2006 at 11:52:50 AM
R2016 - Revit Building Section
Fri, Oct 21, 2016 at 12:02:28 PM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:44 PM
Page generation time: 0.2448
