Forums >> Revit Building >> Technical Support >> Copy Sheets From One Project to Another
Fri, Oct 5, 2007 at 3:25:03 PM | Copy Sheets From One Project to Another
gholmes
All-
 I did a search and didn't see exactly what I was looking for.  I am trying to move or copy one drawing sheet from one project to another.  Basically it is the same project only it is so big that we divided it up into disceplines.  For instance I am trying to move my I-201 and I-202 sheets and the elevation views that accompany them on the file 51031A to 51031I.  The reason I am doing this is because they hadn't created the I-File until a few minutes ago and want all of the I-series drawings on that file instead of the A-series file.
 Basically:
 Wanting to move I-201 and I-202 Elevation Sheets from project 51031A to project 51031I.  Can this be done?
J.T.
Fri, Oct 5, 2007 at 8:51:30 PM | Copy Sheets From One Project to Another
robinballew
robinballew Avatar
3 Stars: 4 Votes
no. The sheets just display the model. If the model doesn't have the views then you cant display the sheets.
BallewDesigns.com
Work around for sheets and new project
Thu, Jul 23, 2015 at 3:59:16 PM
Using standardized detail sheets
Tue, Apr 18, 2006 at 8:43:19 AM
Copy Legend to New Project?
Wed, Feb 20, 2013 at 3:37:10 PM
13
Multiple sheets with the same name.
Fri, Oct 18, 2013 at 7:19:00 AM
Copy/paste section to new project
Thu, Sep 10, 2015 at 10:21:13 AM
Page generation time: 0.7788
