Forums >> Revit Structure >> Technical Support >> grids generator "extensions4revit"
Wed, Oct 3, 2007 at 7:51:19 PM | grids generator "extensions4revit"
chaggas
       I am exploring the uses of 'grids generator’, one of the free downloads in extensions4revit, and I am curious if anyone else has experience in using it. I am particularly interested in how anyone is modifying their generated grid as I am getting a warning every time that I attempt to use the software. The warning reads, "All tracked changes will now be cleared." While I can't boast to know exactly what this means, what happens is instead of modifying the existing grid and objects that are populating the grid; it simply generates a new grid..... and places it directly on top of the old one. I then would have to sort out and delete the old grid and what it's populated with... if I delete it before modify of course I come across the error that there is nothing to modify. .....so I just have to get it right the first time. Anyone else out there in the great blue yonder have experience with this? Here is the link to robobat where I downloaded this. http://www.extensions4revit.com/n/e4rAs always thank you in advance for any help or direction you can offer.
Cynthia
Typical Detail Library
Fri, Mar 7, 2008 at 9:44:59 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Column Grid Question in Revit 2008
Sat, Apr 26, 2008 at 4:56:38 PM
When I copy an "existing" element it reverts back to "new construction."
Mon, Jun 16, 2008 at 2:38:24 PM
tagging by "family name" and "family type"
Mon, Jun 1, 2009 at 8:54:54 PM
Page generation time: 0.7604
