Forums >> Revit Building >> Technical Support >> Square Lines and Corners in Revit 2008
Wed, Oct 3, 2007 at 5:08:42 PM | Square Lines and Corners in Revit 2008
klbasford
Our office is working on Revit 2008 and we are noticing one major disturbance.  When creating dashed/demolished lines with a heavy line weight, each segment is rounded at the ends.  We need dashed lines that are square at the corners of each segment.  How can we change the settings to make this happen.
 Also, when printing our files, heavy line weights create rounded corners on elements. i.e. when we print an elevation, the corners of a wall are rounded with a heavier line weight.  is this problem fixable?
Thu, Oct 4, 2007 at 6:58:21 AM | Square Lines and Corners in Revit 2008
You can't fix this and it has been one of my complaints also.  Please add your voice in the autodesk's site for REVIT asking them to correct this.
Your work around is to add thin lines at the corners.  Might be able to setup a thin line bordered fill detail element that uou could place in corners but what a pain.
Square Ended Lines
Wed, May 18, 2011 at 8:03:23 AM
Change appearence of lines
Tue, Apr 8, 2008 at 6:29:17 AM
Revit Architecture 2013 - Cannot dimension endpoints of walls/corners. HELP!
Thu, Jul 18, 2013 at 8:24:17 PM
Wall Square footage
Wed, Aug 27, 2008 at 3:57:20 PM
Square Yards calculations
Mon, Mar 19, 2012 at 3:00:43 PM
Page generation time: 4.8621
