29 Users Online (27 Members):
Forums >> Revit Structure >> Technical Support >> Curtain wall visiblilty
25 Posts No Rating |
When I try to draw a curtain wall I get this warning : None of the created elements are visible in Structural Plan: LEVEL TWO View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings. What can I do to make curtain wall visible?
In structural plans curtain walls are not visible because they are not structural. Change the setting under View Properities to Architectural.
----------------------------------- BallewDesigns.com |
that worked. Thank you
2 Posts No Rating |
I am having the same problem. When I change the discipline to Architectural or Coordination, my framing becomes invisible. I also noticed that strangely some of the curtain walls do appear.
Curtain Wall Panel to Curtain Wall Door |
Curtain wall not cutting through moulding |
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall |
Sat, Jan 10, 2009 at 10:01:35 AM
