Forums >> Revit Building >> Technical Support >> stair stringer control question
Tue, Oct 2, 2007 at 9:56:28 PM | stair stringer control question
ktrain
I am working in Revit Architecture 2008. I would like some help in learning how to make my stringers on my stairs out of steel channels. I would also like to know how to center the treads within those stringers if anyone can give me any advice. Right now the stringers default to below the treads except if I change the stair type to wood, but I obviously want to do steel stairs. I only see an offset option that changes the depth of the stringer relative to the tread but it won't let me raise the top of the stringer past the tread. Hopefully that makes sense. Thank you ahead of time everyone!
Stair Stringer Question
Fri, Jul 28, 2017 at 4:01:08 PM
Stringer in Stair by Run: Problem with offset
Tue, May 6, 2014 at 7:44:18 PM
Monolithic Stair with Stringer
Wed, Aug 5, 2009 at 10:43:24 AM
Stair - end riser flush with stringer
Tue, Mar 3, 2009 at 5:57:58 AM
Stair Stringer Offset
Wed, Jul 15, 2009 at 2:20:56 PM
Page generation time: 2.1526
