Forums >> Community >> Newbies >> Creating a Roof Plan in Revit
Tue, Oct 2, 2007 at 7:29:48 PM | Creating a Roof Plan in Revit
rcobbjr
3.5 Stars: 3 Votes
I am trying to generate a roof plan for a residential project. When I view the roof level it shows the roof but it looks as if it is cutting a square in the roof as if it is not able to view the roof beyond a particular point vertically. I am able to look into the space (room) under the roof. How can I create a roof plan from my model?
Wed, Oct 3, 2007 at 8:51:58 AM | Creating a Roof Plan in Revit
robinballew
robinballew Avatar
3 Stars: 4 Votes
Adjust your View Range.. Open view, right click,View Properities,View Range, Cut Plane ( adjust taller) You will also need to adjust the Top so it is higher than the Cut Plane..
BallewDesigns.com
Roof plan
Fri, Sep 2, 2016 at 4:58:14 PM
Roof Plan Issues- lower roof showing above upper roof
Thu, Dec 10, 2015 at 3:10:46 PM
Roof fascia curves in plan and elevation
Sun, Dec 13, 2009 at 1:40:44 PM
Please Help-Revit 2011-Creating a single sloped roof
Tue, Nov 8, 2011 at 2:50:01 PM
Walls disappear in roof plan after attaching to roof.
Wed, May 30, 2012 at 11:36:02 PM
Page generation time: 1.6552
