16 Users Online (14 Members):
Forums >> Revit Structure >> Technical Support >> JOIST GIRDER INQUIRY!
2 Posts No Rating |
Hi All,I have been working in a Revit Structure Model where I suppose to replace a 28LH girder with a 36G4N joist girder on a 48'-9" span. Apparenty, it cannot be done because I get an error message that says it cannot create this type of girder. I want to mention that 36G4N8K type does not exist in the library. After few attempts to create one we failed. OK, I have tried to trick the model and to use a 36LH size but I get the same error, probably because the depth is to high for this span. My engineers told me that a 36LH cannot span on a 48'-9" but a 36G4N8K should work just fine. So, I reached a stopping point and I desperately need help. Any suggestions would be greatly appreciated.Thanks a lot.Sincerely,Dan Ungureanu
I've run into this issue before as well. It seems like revit restricts the depth of a joist relative to the span length. Knowing this led me to investigate deeper into a formula with in the family. What I found that made the difference was the formula for "End Panel". If you look into it, yours probably says 2.0*Length. If you change this to be 1.5*Length it should give you the chance to make deeper joists for shorter spans. NOTE: This does change spacing of the end panels. Not that anyone would ever notice it. HTH JB
2 Posts No Rating |
Please help! I also have girder problems only i need to make a lattice girder that can change its height and length without changing the unit angles in between. So if I want it to go longer it should have more units in and thay should grow proportionately bigger as the height increases. Is it possible to do this?
joist girder |
Tue, Oct 30, 2007 at 8:37:47 AM
double pitch joist girder |
Thu, Dec 18, 2014 at 11:43:59 AM
Joist Girder with sloping top chord |
Mon, Sep 22, 2008 at 10:10:11 AM
3 Panel Joist Girders |
Thu, Feb 26, 2015 at 10:00:53 AM
Tapered Joist Girder & modified K series to match roof slope |
Thu, Aug 20, 2009 at 2:51:06 PM
