Forums >> Revit Systems >> Technical Support >> How do I bring a drafting view from one project into another???
Mon, Oct 1, 2007 at 3:08:28 PM | How do I bring a drafting view from one project into another???
doza10
Mon, Mar 3, 2008 at 4:28:26 PM | How do I bring a drafting view from one project into another???
Westview
2.5 Stars: 2 Votes
The quickest way would be to have both projects open and copy the drafting view to the clipboard and paste it into the new drafting view.
Mon, Mar 3, 2008 at 5:57:35 PM | How do I bring a drafting view from one project into another???
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
The easy way is to simply go FILE > INSERT FROM FILE > VIEWS then browse to the file that has the DV that you want to insert. Revit will create the view with the geometry for you.
However, this really is only good for one use as it has a tendancey to create more work than it's worth. If the file you are inserting INTO already has this drafting view, it will duplicate the drafting view as well as the elements inside the drafting view.
For example: Let's say you are setting up a detial library using .rvt files with drafting views and you insert a ftg detail into your project. Three hours later there is an update to this deatil so you reinsert this into your project.
If you did not delete the drafting view, any groups associated w/ it, Revit will duplicate them. Now your project has ftg detail 2 inside your project. In some (MOST) cases it will also duplicate detail components associated with the detail. Now you not only have a duplicated view, but multiple components as well...gets to be a really big mess especially if end users aren't watching for this.
Instead I turn the elements from the drafting view into a group, then under the file menu SAVE TO LIBRARY > SAVE AS GROUP.
I then take that group and load it into my project and place it into a drafting view that I made. I do it this way because if the detail changes all I have to is apply those changes to the detail then just reload it and I now have the current version of the detail w/o any of that anoying duplication...it will act more like an xref this way.
Another option you could use is create a drafting view in your project and set it up to match the one that you need and instead of inserting the view, select the 2D ELEMENTS option. That will just give you the elements and not the drafting view...basicaly copy/paste. You have to create the view yourself, but it does seem to limit the duplication.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Mar 4, 2008 at 8:35:53 AM | How do I bring a drafting view from one project into another???
lbrooksher
Thanks Brett.  I'll give that a try when I get to doing true drafting views.  This doesn't work for views made with model elements though... right?
From research so far, it seems like views made with model elements cannot be exported.
For example, I needed to do another bathroom option, but "options" was going to be overly complicated with all of the associated model objects. (walls attached to floors, doors in walls, etc.)  I made a copy of the file and made the changes and now want to bring the view into the original model sheet as an option. The only solution that I have found so far is to print it as a pdf, save it as a jpg and import it into a view.  Of course, I have to redo all of that any time a change is made to the second bathroom option, as it can't be linked.
We have another situation where we have multiple buildings in their own models, but we want the code plans to be all on one sheet.  Again, we can't seem to get those views into the model that has the code sheet
Is this even possible.  It seems like a basic idea.
Cropping drafting view
Fri, Mar 2, 2018 at 3:28:48 PM
Would like to copy a drafting view from one project to another. [ 1 2 ]
Mon, Jan 4, 2016 at 6:07:17 PM
17
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
what is the best "work around" for croping drafting views
Wed, Jan 23, 2008 at 9:38:01 AM
Drafting view
Thu, Aug 6, 2015 at 1:41:00 PM
Page generation time: 0.9400
