13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Visibility question
I cant figure out why the crown on the [plan] left doesnt display. they were created one after the other as extrusions, same visibitily settings, defined as casework, casework is ON in the plan. Thoughts???
Yeah i've experienced graphic glitches like this before. Can be cause the cut plane is set to be exactly on the element, try adjusting slightly to make sure the cut plane is actually cutting the element. Otherwise you may have to resort to using the linework tool on the particular lines you wish to display.
HTH.
I agree with your theory re cut planes, but in order to create the component>solid you have to specify a work plane, and both sides have the same work plane, exactly the same height off the floor.
3d Visibility Question |
Thu, May 25, 2006 at 7:59:04 AM
Stair Visibility Question in 2008 |
Sat, Sep 1, 2007 at 1:39:42 PM
Question about rebar visibility in Shaded view |
Mon, Apr 29, 2013 at 2:19:18 PM
visibility graphics question |
Mon, Jun 15, 2009 at 1:33:52 PM
Visibility Parameter in Room Tag |
Fri, Jun 4, 2010 at 6:01:09 PM
