Forums >> Revit Building >> Technical Support >> Keynoting Help
Sun, Sep 30, 2007 at 11:03:22 AM | Keynoting Help
rgaaia
I have used keynotes effectively but I now want to add a cover sheet with ALL of the notes used in the project in addition to the notes used sheet by sheet.............is there a way to do BOTH........?????
Mon, Oct 1, 2007 at 4:34:48 AM | Keynoting Help
MikeChan
3 Stars: 5 Votes
I am not 100% sure what you asking. But my best guess is you having Keynotes everywhere in your project plus some text notes on sheets.
To sort out the Keynotes to display on print sheet is easy, just create a Keynotes Legend, play around with the sorting, then you will get that. However, the text notes are the problem here, because general text note have no parameter, so it cannot be schedule. A work around will be create a symbol use as text note from generic annotation family, add some parameter on it so you can use for sorting, load it into your project, then create a Note Block (schedule).
 I think you know what to do next, so I don't descript too detail here. Hope it help you.
Mon, Oct 1, 2007 at 2:35:56 PM | Keynoting Help
utburn4242
I have done this by duplicating my Keynote Legend.  One instance only displays the notes on that sheet.  This is the one used throughout my set.  And the other Keynote legend displays all instances.  That one is used on my general conditions sheet.
hope this helps
Tue, Oct 2, 2007 at 8:46:51 PM | Keynoting Help
rgaaia
yes I will try the duplicate one........
thanks for the great idea....
Tue, Oct 2, 2007 at 8:53:51 PM | Keynoting Help
rgaaia
UTburn4242!!!
thanks it worked .......duplicating the schedule and unchecking the "filter by sheet box" allowed me to put ALL of the project notes on the cover sheet....while using the other schedule filtered by notes used by each sheet......
Keynoting
Tue, Aug 28, 2007 at 4:28:31 PM
KEYNOTING!!!
Thu, Mar 17, 2011 at 2:16:59 PM
Font for Keynoting legend symbols
Tue, Jun 30, 2009 at 11:09:36 AM
Keynoting in Legends
Thu, Jan 24, 2008 at 2:42:43 PM
Revit 2010 - Keynoting dependent plans
Tue, Jan 5, 2010 at 10:48:39 AM
Page generation time: 1.7360
