10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Connect cameras for animation
Can you connect different cameras set up to create a flythrough animation? I dont' want a walkthrough. I want a bird's eye view animation around my building? I'm using Revit 9.1 thanks.
Denver, CO
Revit Architecture |
i think the process would be the same, just confine your camera path to the exterior of the building.
Just to add to the above. Let suppose you are setting up the flythru scene at the Site Plan level. When you add the camera location, notice the default height (eg: 1750mm) on your menu bar. Change the height to say 50000 to give you an bird eye view. You do the same each time you click the camera position. Once you finished, at the walkthru edit mode, adjust the camera position to zoom in your subject. Here you can also open each camera view to readjust the height if required so. Have fun with the fly thru.
----------------------------------- G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong. |
Saving partial animation before end of key frame |
Wed, Dec 8, 2004 at 9:17:21 AM
Connect Into Setting |
Thu, Feb 13, 2020 at 8:02:52 AM
Camera Settings for a Walkthrough animation |
Tue, Dec 4, 2018 at 12:04:26 AM
Rvt 2009 Showing and printing Cameras in plan |
Thu, Mar 26, 2009 at 6:45:20 AM
Controlling Revit animation speed |
Tue, Sep 16, 2008 at 4:18:01 PM
