Forums >> Revit Building >> Technical Support >> Is there a way to put specific objects you created on a differnet layer?
Fri, Sep 28, 2007 at 4:42:03 PM | Is there a way to put specific objects you created on a differnet layer?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I'm using Revit 9.1.  Can I put massing I created in place in a specific category...i.e. Roofs?? thanks
Denver, CO
Revit Architecture
Thu, Oct 25, 2007 at 10:11:08 AM | Is there a way to put specific objects you created on a differnet layer?
IDN101
2.5 Stars: 3 Votes
Yes,
 Use the "Modelling" Design Menu. Select "Create..." from near the bottom. Choose from the drop down list, which category you want to create your mass in.
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Thu, Oct 25, 2007 at 10:18:20 AM | Is there a way to put specific objects you created on a differnet layer?
rat69
What if the object has been already created? Is it possible to asign/change categories?
Thu, Oct 25, 2007 at 10:40:03 AM | Is there a way to put specific objects you created on a differnet layer?
IDN101
2.5 Stars: 3 Votes
I don't believe so.
This method of creating components is "quicky and dirty"! But that results in limited flexibility.
Ian
www.RevitZone.com
Thu, Oct 25, 2007 at 1:34:30 PM | Is there a way to put specific objects you created on a differnet layer?
If it is really a family, most of the time you can change its category but I don't know about in place families.   - Haven't tried that because I don't like in-place families.
same object, differnet colors
Tue, Feb 7, 2012 at 3:34:56 PM
Making Different Items be on a Specific Layer
Wed, Sep 9, 2009 at 12:42:17 PM
Chaning mass objects
Fri, May 8, 2009 at 3:41:08 AM
Problem with Exporting to dwg with multiple layers for use in 3D Studio
Mon, Dec 13, 2004 at 5:21:21 AM
Structure objects created in Revit Architecture 2010 Service Pack
Mon, Jan 18, 2010 at 9:59:10 PM
Page generation time: 0.4825
