19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Printing to pdf format
1 Posts No Rating |
HI, I would like to print to PDF much the same way as we use Autodesk DWF Writer to print to DWF Is that possible? Rick
as long as you have a pdf printer driver installled you should have no problem printing to PDF.
Hi Coreed, If you have the pdf printer driver installed, is that mean the "Publish PDF" will appear in the pull down menu in Revit? Or it will only appear in the Printer Setup. If possible can you show us how it looks like on the attach file. I too is interested to publish my drawing in PDF. Some of my client just refused to accept WDF file! Thanks.
----------------------------------- G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong. |
5 Posts No Rating |
hey kimwong: the print driver spoken of is a driver installed by windows programs (ie: acrobat 8 professional)...general statement: regardless of your program... if you slect the windows printer with pdf driver it should pop up when printing... i have found that sometimes you will have to set it to the default windows printer for the prog to recognize it... there are many printer progs that print emulate to pdf (ie: pdf machine... acrobat 8... just google them as print to pdf)... good luck in australia... oldtexas
here is screen shot of the Print Dialog box. Ounce install your PDF print driver you select it like any other printer
Edited on: Sun, Sep 30, 2007 at 8:52:20 AM
Thanks Coreed. Look like I have to install a Adobe Acrobat PDF converter here! On the subject of PDF, what is the difference or how good is PDF 3D compare to WDF 3D? Anyone with a good experiences on PDF 3D to throw some light here? The new Autodesk Design Review 2008 for WDF 3D is great. Thanks.
Printing files to PDF format in Revit 2008 Building |
Fri, May 30, 2008 at 1:03:04 PM
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
printing large formats in pdf |
Thu, Dec 29, 2011 at 6:25:11 PM
Printing in Revit |
Tue, Apr 28, 2009 at 10:50:38 AM
Printing Shadows in .pdf file - Revit 7.0 |
Wed, Dec 22, 2004 at 9:16:23 AM
