Forums >> Revit Building >> Technical Support >> Revit 2008 Rounding Numbers Up
Fri, Sep 28, 2007 at 1:49:45 PM | Revit 2008 Rounding Numbers Up
nicolle
4 Stars: 1 Votes
does anyone know of a way that i can get my numbers to round up?  i've read some of the posts regarding why this is occuring so i understand the reasoning.  i am doing a schedule and i am trying to see if there is a formula that i can write to make numbers round up to the next whole number, maybe an "if" statement?  i need ANYTHING that would normally round down to round up.  for example, if i had an area that is 2.49sf then i need for it to round up to 3 instead of down to 2.  i think that the rounding is embedded in the program somewhere, and i can't figure out where to view how this is being done.  i've already edited my project units, so what i'm trying to figure out is more where the information for areas is being pulled from.  any help or suggestions will be greatly appreciated.
Fri, Sep 28, 2007 at 2:09:55 PM | Revit 2008 Rounding Numbers Up
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
We use a forced round-up in our occupancy schedule because all fractions of people count as a whole person. We make a parameter of integer type and have it do the formula and add .4999 to the results. For instance, "Area / SF per Person + .4999". 1.2 becomes 1.6999 and rounds up to to 2...1.8 becomes 2.2999 and rounds down to 2. we use .4999 instead of .5 in case the formula generates an integer result like exactly 300sf divided by 15 sf/person = 20 whole people which don't want to become 20.5 and round up to 21. Hope this helps.
Fri, Sep 28, 2007 at 2:15:53 PM | Revit 2008 Rounding Numbers Up
nicolle
4 Stars: 1 Votes
thanks.  i am doing an occupancy schedule.  i'll try this method.
Thu, Nov 1, 2007 at 4:50:41 PM | Revit 2008 Rounding Numbers Up
dashgarnett
Thanks a bunch...this worked great. I have been trying to figure this out for an hour....
 you da man.
Fri, Oct 17, 2008 at 12:46:28 PM | Revit 2008 Rounding Numbers Up
khardy
Perfect! - thank you for sharing.
Tue, Mar 29, 2011 at 9:27:25 PM | Revit 2008 Rounding Numbers Up
Ryan0108
Thanks!  This is probably the easiest integer round up tutorial for a code schedule anywhere...
Rounding in Formulas
Wed, Mar 13, 2013 at 8:49:48 AM
Dimension Rounding
Thu, Aug 23, 2007 at 2:54:31 PM
Area Tags - Rounding refuses to change
Tue, Feb 10, 2015 at 8:22:13 PM
AREA SCHEDULES ROUNDING TO THE NEAREST
Wed, Dec 20, 2006 at 4:36:48 PM
Rounding Issue in Schedules
Mon, Jan 9, 2017 at 2:07:07 PM
Page generation time: 1.6996
