Forums >> Revit Building >> Technical Support >> Brick Pattern
Fri, Sep 28, 2007 at 12:34:40 PM | Brick Pattern
MattEarl
5 Stars: 2 Votes
Hey Everyone!  I was hoping to get some help on making a 6x12 brick pattern... I have no idea where to even start.  Could someone point me in the right direction?
Sun, Sep 30, 2007 at 9:02:55 PM | Brick Pattern
hugh
3.5 Stars: 4 Votes
Search your install for revit.pat - a text file containing some sample patterns and instructions in its heading comments.
This tutorial is for AutoCAD - the tecniques can be used to create new Revit patterns - just remember to add the TYPE=MODEL line to indicate a model pattern.
 http://www.afralisp.net/lisp/hatch.htm
hth
Hugh
Hugh Adamson
www.hatchkit.com.au
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:48:59 PM
brick pattern not consistent
Wed, Mar 16, 2011 at 1:22:14 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:16 PM
vertical brick pattern
Tue, Sep 11, 2007 at 3:08:31 AM
Utility brick pattern
Wed, Dec 27, 2006 at 8:37:41 AM
Page generation time: 1.5202
