Forums >> Revit Building >> Technical Support >> Checking if a parameter value is a integer or a real
Thu, Sep 27, 2007 at 1:41:23 AM | Checking if a parameter value is a integer or a real
johnda
Revit 2008
Does anyone have any way of determining if the true value of a parameter is an integer or a real eg 4 or 4.2.
If this was in a if statement it would be perfect
Cheers John A
Thu, Sep 27, 2007 at 11:22:39 AM | Checking if a parameter value is a integer or a real
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
This is theoretical...sorry don't have time to fully test it, but here goes:
Make a parameter that is an Integer type. Set its formula to be equal to the Parameter you are checking. It should round off any fractions. Then you can make a parameter with an IF statement that checks whether your original value and the "integer"ized value are equal...if they are, then the original was an integer to begin with, if no...it wasn't.
Just taking a shot.
Tue, Jan 15, 2008 at 8:24:55 PM | Checking if a parameter value is a integer or a real
ExpoHire
I have been using this for Arrays.  I needed to return an Integar value, not a rounded value.  Revits Integar isn't technical correct.  Using the INT command in other programs will return 5.9 as 5 where Revit will return 6.
I have be using this to figure out complete sheets (4'x8' sheets).  I have two family parameters, one is Number type and one is Integar, they are both calculated off the equation (which is Dimension to be Covered divided by Sheet Width)
If(Number > Integar, Integar , Integar -1)
 -1 takes the 5.9 rounded to 6 back down to 5,  as an integar should be
Wed, Jan 16, 2008 at 6:48:49 AM | Checking if a parameter value is a integer or a real
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
If all you need is for Revit to always round up, that's a lot easier. Using your example make an integer type parameter with formula
= Length / Sheet Width + .4999
5.3 becomes 5.7999 and reports as 6...5.7 becomes 6.1999 and reports as 6.  It's .4999 and not simply .5 in case Length divided by Sheet Width returns an integer in the first place it will round back down to the integer.
'Inconsistent units" error in parameter formula; length vs integer
Fri, Dec 13, 2013 at 10:37:04 PM
integer parameter problem
Thu, Jun 14, 2007 at 3:15:37 PM
Conditional toggle yes no formula
Thu, Mar 3, 2016 at 8:49:22 AM
How/When do I use each Parameter?
Wed, Jan 21, 2009 at 10:21:02 AM
family with (3) or more yes/no options
Wed, May 18, 2016 at 7:38:51 AM
Page generation time: 3.6025
