Forums >> Revit Building >> Technical Support >> Wall openings
Wed, Sep 26, 2007 at 4:14:30 PM | Wall openings
simonglover07
Is there a way to make a wall opening that doesn't cut through the wall.  In other words, a niche in a wall that can be used for built-in cabinetry.  I'm using 2008 version.  If anyone knows how to, please let me know.
 Thank you
Sat, Sep 29, 2007 at 4:10:54 PM | Wall openings
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can use the Hosted reveal and draw your profile. Reveals cut geometry out of walls. HTH
Tue, Oct 2, 2007 at 9:10:43 AM | Wall openings
Hence
1 Stars: 1 Votes
You  could also create a family, using generic model hosted in a wall, and create a void form with in the wall (make sure you tell revit to "cut" the wall geometry with the void form).  That way you can add molding or any other details to the opening and just repeat it as a family in the model.
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Coordination review with wall openings
Tue, Sep 18, 2007 at 8:57:20 AM
Wall Openings
Mon, Mar 9, 2009 at 2:40:22 PM
Exclude wall openings and windows etc from wall schedule
Tue, Nov 12, 2013 at 4:46:24 AM
OPenings through multiple walls?
Mon, May 24, 2010 at 4:48:54 PM
Page generation time: 2.1771
