Forums >> Revit Building >> Technical Support >> Show rooflines and wall lines in plan
Wed, Sep 26, 2007 at 10:34:30 AM | Show rooflines and wall lines in plan
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
How do I show the hatched roof lines above in my floor plan.  Also how do I show my hatched wall lines below in my roof plan?  I am curious if there is a way to do this so it updates with edits.  Rather than me draing a simple line.  Thanks,
Lorne17
Denver, CO
Revit Architecture
Wed, Sep 26, 2007 at 11:40:09 AM | Show rooflines and wall lines in plan
jterrell
3 Stars: 5 Votes
There is a couple of ways to do this:
 1.    Turn on the roof level as an underlay in the view and modify the roof linestyles in the object properties (also shows ridge/valley lines)
2.    Turn on roof as an underlay and use the linework tool to change the linestyle of the roof edges. When you turn the underlay off, the edges you changed will still be visible in the view.
Wed, Sep 26, 2007 at 12:10:06 PM | Show rooflines and wall lines in plan
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Awesome....works great for both roofs above and walls below thanks!
Denver, CO
Revit Architecture
Rooflines
Fri, Oct 7, 2005 at 2:15:49 AM
Help with rooflines!!!
Sat, Aug 5, 2006 at 2:48:21 PM
Show ceiling/roof lines as hidden lines on floor plan
Mon, Aug 17, 2009 at 12:24:44 PM
How do I get to show lines dashed in plan view?
Sat, Oct 24, 2015 at 4:57:45 AM
Tue, Jan 23, 2007 at 3:20:52 PM
Page generation time: 8.7873
