37 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Dimension center line of foundation
Wed, Sep 26, 2007 at 10:01:07 AM | Dimension center line of foundation
burke424
How do I dimension to the center line of a foundation wall? All I can select is the faces even when I have center of wall or center of core selected as my preference in th edimension command.
Wed, Oct 3, 2007 at 9:17:40 AM | Dimension center line of foundation
EDGinc
Hit the TAB button while hovering over the wall (while in the dim command)
Or go to the "Settings" pull down menu, then into "Temporary Dimensions" and change it there.
Wed, Oct 3, 2007 at 10:01:15 AM | Dimension center line of foundation
burke424
When I use the TAB key it only toggles between the interior and exterior face of the concrete foundation wall, never selects the center. I checked the settings in the temporary dimensions and they were set to centerline. I tried changing it to center of core but that didn't allow me to select the centerline either. If I set my cut plane for the foundation plan above the foundation so it cuts the stud wall above the foundation I can select the center line of the stud wall that rests on the concrete foundation wall, but then the foundation plan shows the stud wall not just the concrete foundation.
Thu, Oct 4, 2007 at 7:40:43 AM | Dimension center line of foundation
EDGinc
Have you tried this on other Conc walls? Do they all miss the Centerline?
Could it be just a bad element? Try drawing a new wall to see if it fixes the issue.
Hidden dimension segment
Mon, May 3, 2010 at 9:06:52 AM
Dimension to center line of doorway
Fri, Jan 26, 2007 at 10:01:21 AM
dimensioning to a center mark of an arc
Wed, Jul 5, 2023 at 3:13:09 PM
Moving dimension value
Fri, Jul 17, 2009 at 12:07:34 PM
"EQ" dimension on either sid eof a fixed dimension [ 1 2 ]
Sun, Aug 24, 2008 at 12:08:50 PM
15
Page generation time: 1.7659
