Forums >> Revit Building >> Technical Support >> View DWG above objects?
Tue, Sep 25, 2007 at 3:37:53 PM | View DWG above objects?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Is it possible to view the imported .dwg link above the walls?  Or ghost it so I can see it?  Because once my walls are drawn they cover up all the windows and I don't know where they go?  Just curious if there is a simple way around this.  Thanks,
Lorne17
Denver, CO
Revit Architecture
Fri, Sep 28, 2007 at 3:14:58 PM | View DWG above objects?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Also, I'm using Revit 9.1
Denver, CO
Revit Architecture
Thu, Aug 6, 2009 at 7:46:23 PM | View DWG above objects?
Bhavi
Hi,
To see your DWG through your walls, change your Model Graphics style to "Wire Frame".
Tue, Aug 11, 2009 at 8:58:41 AM | View DWG above objects?
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Well since this post is so old, I have found out how to do this.  All you do is select your dwg and under the options bar, change it from background to foreground.
However if you brought it in to be in ALL views, then I don't believe this option is available.  If that's the case, use wireframe view.
Lorne
Denver, CO
Revit Architecture
Exporting views with DWG bocks to dwg.
Sun, May 21, 2006 at 8:36:59 PM
DWG and revit preformance
Mon, May 15, 2017 at 2:24:05 AM
Importing DWG or DXF file objects
Wed, Jul 12, 2006 at 10:45:32 AM
Help: Print transparent objects from floor plan view to pdf in revit 2013
Tue, May 8, 2012 at 2:49:41 PM
3D DWG as a Mass - Visibility Problem
Fri, Sep 5, 2014 at 1:30:53 AM
Page generation time: 2.7135
