Forums >> Revit Building >> Technical Support >> Scheduling cased openings
Tue, Sep 25, 2007 at 12:28:49 PM | Scheduling cased openings
morss
How do you get a cased opening to schedule like a door? I want it to appear in my door schedule.
Morss Medical Architecture
Tue, Sep 25, 2007 at 10:45:26 PM | Scheduling cased openings
robinballew
robinballew Avatar
3 Stars: 4 Votes
Cased openings are not doors. As you noticed you don't use the "Door" tool to insert Cased Openings. All you need to do is edit the family and change the Family Category and Parameters to Door. After the change reload the opening and they will show up in the schedule.
BallewDesigns.com
Wed, Jul 23, 2008 at 3:55:01 PM | Scheduling cased openings
twhisker
2.5 Stars: 5 Votes
You can get a cased opening in a door schedule and you would want that if it were a HM framed opening - these need to be scheduled as well because of the frame.  It may not be as critical if it is a wood framed opening with trim as that is not something that needs to be sized and purchased.  You can use the cased opening family out fo the box from Revit.  There are also some good door familys on revit city that have HM frames - you can rework them to frame only.
Revit Architecture 2010
Cased openings
Wed, Jan 23, 2008 at 10:10:24 PM
Cased openings not displaying casing.
Thu, Jun 18, 2009 at 10:55:21 AM
Openings
Thu, Jan 28, 2016 at 10:57:11 AM
Cased openings
Sun, Jun 17, 2007 at 5:48:46 AM
how do I load cased opening and arched openings
Wed, Sep 28, 2011 at 3:05:58 PM
Page generation time: 0.0496
