Forums >> Community >> Newbies >> Custom Linetypes
Tue, Sep 25, 2007 at 8:05:09 AM | Custom Linetypes
Brandon2008
I was wondering if there is awayway to heavly customize linetypes for instance the outline of the cabinet will be slightly darker the the handels.  Or the outline of an appliance will be darker and the detials will be much ligher.
Tue, Sep 25, 2007 at 9:54:44 AM | Custom Linetypes
kkohutek
kkohutek Avatar
4 Stars: 7 Votes
As far as we know Revit still doesn't have this option
You can do it manually, by changing the Phasing
Select the object you want to be View properties... > Phasing >
Phase created > Existing
Phase demolished > None
Your lines will be gray.
Phase demolished > New construction
Your lines will be hidden lines.
Phase demolished > Existing
Your lines will disapear.
Phase created > New constuction
Phase demolished > New constuction
Your lines will be blue hidden lines.
Phase created > New construction
Can't do it.
In this case these lines are in a Section view. The thing is... The lines will also change in every view. Some lines may change the element into red colors.
I would do a separate final file and change these lines and use the images only with the views you want.
Well, this is a way. Don't know if people knows anything different.
Hope it will help Smile
Tue, Sep 25, 2007 at 11:03:21 AM | Custom Linetypes
You can add the linetypes in your family but they will not be a linetype in your project.  They will show up in VG in the category your family is in.
Wed, Nov 7, 2007 at 5:53:17 PM | Custom Linetypes
Architectureguy
Architectureguy Avatar
Our office has set up varied linetypes with different weights into the revit template model. It's the same types in all our component and profile templates as well. As long as the linestyle you use is also in the project model, then you should be good to go.
Complex Linetypes in Revit?
Mon, Jul 2, 2012 at 1:51:38 PM
DWG Revit export replacing linetypes with erronous linetypes
Tue, Mar 17, 2015 at 10:07:42 AM
Getting CAD Linetypes into REVIT
Thu, Jul 24, 2008 at 7:11:10 PM
Linetypes and Phases
Thu, Dec 1, 2005 at 5:29:34 PM
Family linetypes
Thu, Jan 31, 2008 at 1:15:43 PM
Page generation time: 1.6133
