Forums >> Revit Building >> Technical Support >> Calculation in Room Tag
Mon, Sep 24, 2007 at 11:14:55 AM | Calculation in Room Tag
twhisker
2.5 Stars: 5 Votes
In my room schedule, I have created a calculated field for occupancy load.  It divides area by occupancy load factor, which is a shared parameter I have created for rooms.  It works great and is in my schedule, but I cannot find how to add it to my room tag.  (Revit Arch 200Shadey Any ideas?  Thanks.
Revit Architecture 2010
Mon, Sep 24, 2007 at 1:37:56 PM | Calculation in Room Tag
laurabh
You can't show a calculated value in a tag.  One way to get around it is to add another shared parameter called "Occupant Load Tag", place it as a field in your schedule next to the calculated field, and then manually type in the numbers that were calculated.  You can add this parameter to your room tag.
Mon, Sep 24, 2007 at 2:12:19 PM | Calculation in Room Tag
twhisker
2.5 Stars: 5 Votes
That worked!! Thanks.  Not exactly the relational database I hoped for but enough to get the information on our plans.  Just have to monitor any changes.
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
room area calculation
Thu, Jan 15, 2009 at 5:51:20 AM
Editing a room tag
Thu, Oct 12, 2017 at 3:17:41 PM
Heat loss calculation formula
Wed, Apr 29, 2009 at 10:09:09 AM
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Page generation time: 5.7754
